- Mon Oct 24, 2011 12:04 am
#278802
I bought a 93 civic with what I thought was a full d16z6 engine in it. Got to looking at the head and it says po8-1. The valve cover doesnt say v-tec. Im popping the V-tec solenoid code but when I went to swap in a new z6 solenoid, it isnt the same. Am running a p28 ecu if that matters at all. Just need help finding out what head is on it so I can get this solenoid swapped and the car running better.
94-95 D16z6 looks like this:
All 4 D16z6's I have owned have heads stamped "p08" 3 of them have "p28" Intake Manifolds, one of them(from my delsol) had a p08 stamped intake manifold even though it looked the same as the p28 version.
The p28 ECU is the correct ecu. If swapping out Vtec solenoids doesn't work try cleaning it out with carb cleaner. If it still doesn't work then its wiring in bewteen the vtec solenoid and the ecu. Its possible you have the VTEC wiring on another sensor.
