- Tue Jan 10, 2012 6:19 am
#289263
I have a 94 CX with the D15B8 (non v-tec OBD1) and I just picked up a D16Y8 (v-tec OBD2) I was wondering if it is worth the hassle for the OBD 1-2 switch or if I can make my wiring work and just add the v-tec wiring. Any help from someone who has done this would be greatly appreciated.
- Tue Jan 10, 2012 6:21 am
#289264
Either way you will have to change out the dizzy and all the sensors on the head to keep it OBD1 easier to just find a ex or si engine harness and use it to do the conversion with as well as all the sensors you would need. or find someone to selling a complete Z6 swap with harness and pick it up.
- Tue Jan 10, 2012 7:10 am
#289266
Can I just use my dizzy and sensors from the old head and basically follow the Mini-me DIY?
- Tue Jan 10, 2012 7:14 am
#289267
You will need a d15b7 dizzy for that head to make it work right there are a ton of right ups on it d-series.org most sensors should work, might need to change out the coolant ones though so that v-tec engages properly as well as the oil pressure sender unit. My friend was going to put a complete y8 into his 95 coupe and we found this info out so he is using the block and putting a z6 head onto it.
- Tue Jan 10, 2012 2:25 pm
#289309
or an obd1 to obd2 alternator harness is $35
https://www.google.com/#q=obd1+obd2+alt ... qf.,cf.osb
Ignore the knock sensor and cfk sensor on the block. Also the injector slips will be different.
- Fri Jan 27, 2012 10:08 pm
#292287
I have a D16Y8 for sale
I am just gonna get a JDM DZ16 (DOHC) a little over $1000 delivered w/ ECU
- Sat Jan 28, 2012 1:10 am
#292313
I don't know of a JDM DZ16... do you mean JDM DOHC ZC?
That's an old motor, I think your $$ could be better spent buying a LS swap for under $1k.
Or go with a JDM D15b for about half the cost and power will be about the same PLUS you'll have vtec.
Andytastic wrote:I have a D16Y8 for saleI am just gonna get a JDM DZ16 (DOHC) a little over $1000 delivered w/ ECU
