- Thu Jan 19, 2012 4:47 pm
#291009
Right just swapped my D13 for a D16, went to see if it would work, and nothing, no priming of fuel tank but I have lights, electric windows working. But the old Honda security system was clicking which Ive never heard before, anybody got any ideas, have I missed something etc
- Thu Jan 19, 2012 5:09 pm
#291011
what all did you swap along with the motor?
- Thu Jan 19, 2012 5:29 pm
#291022
Make sure the battery is nice and tightly connected
Had this happen to me on my old Coupe and turned out battery would get a bit loose.
- Thu Jan 19, 2012 5:56 pm
#291026
I'l check battery.
I swapped interior loom, fuel tank/lines, ecu etc
- Thu Jan 19, 2012 6:05 pm
#291028
check all of your fuses grounds etc?
- Fri Jan 20, 2012 2:23 pm
#291196
i agree you need to check all grounds and check starter relay and fuse
John Pritchett Is my hero
- Fri Jan 20, 2012 2:32 pm
#291199
Ground should be connected on valve cover, transmission and most importantly, thermostat housing.
- Fri Jan 20, 2012 3:57 pm
#291205
i sand it a little with emory cloth to make a good contact
teal_dx wrote:Ground should be connected on valve cover, transmission and most importantly, thermostat housing.
street machines > dyno queens
z6 turbo power FTW tuned on crome
- Sat Jan 21, 2012 9:57 am
#291316
Right I think I'm missing a earth wire, anyone got pictures of where there all supposed to be
- Sat Jan 21, 2012 1:17 pm
#291321
All earth wires connected, still nothing, I think it might have something to do with the Honda security system
- Sat Jan 21, 2012 3:48 pm
#291340
sometimes just connected aint enough without being tight enough
- Sat Jan 21, 2012 5:27 pm
#291355
They are tight
- Fri Jan 27, 2012 8:24 pm
#292268
well it could be an ecu maybe but if your security deal is clicking that might be it but i dont have any experience with those on hondas chevrolets just makes it to where the radio wont work
