- Sat Mar 31, 2012 11:17 pm
#300503
Alrite... I have a d16y7 engine in my car now and I was looking into getting a d16z6 to put in... I plan on building it eventually... but is it worth it or should I just build the y7... also wat duos I need for the swap besides the engine
- Sat Mar 31, 2012 11:58 pm
#300511
Which model hatch? and yes depending on your model, you will need the wiring harness from the z6 and then all you should have to do is wire up the vtec to the ecu. other than that depending on engine side motor mount that is about all you should really need. everything else is the same
#300512
It will drop right in and you'll have to wire it for.vtec if you don't have the harness from the d16z6
- Sun Apr 01, 2012 12:31 am
#300519
Oh well shit you won't have to do anything besides swap it in then. Should be good to go just make sure your engine bracket for the motor mount matches the mount and your set. other than that you will want to find a P28 if its not still in the car so that everything works properly.
- Sun Apr 01, 2012 1:19 am
#300524
Should be yeah, you won't need to do anything to the chassis harness it should just be plug and play, have you checked the harness on the motor currently to see if the vtec plug is not just dangling there. if it is that might be your factory z6 harness on that y7
