- Mon Apr 02, 2012 9:55 pm
#300706
I have been having this problem for over a year now and no one has been able to figure it out. After the car is warmed up it idles at like 200rpms. It also sounds like its got a miss, it sounds like a 4 stroke dirt bike. Here's what I've replaced trying to fix it: completely new Dizzy, plugs wires, new iacs, coolant temp sensor, throttle body, map sensor, tps,pcv, o2 sensor, fuel filter,thermostat, coolant flush,ecu, timing, I've tried adjusting the screw on the tb and that doesn't fix it. It doesn't have a cel. The car idles worse the hotter it gets outside. In the winter its fine. The car doesn't have a blown head gasket. What the hell is wrong?
Whats in the Garage..... Well the yard!
1995 Honda Civic - DX - 91.5 CID...
1987 Toyota Supra - NA Hard Top - 1UZ-FE In - Going AEM then ITB's!!!!!!
1976 Honda CB550K - Old School Kool - Half Cafe'd
-Almost Stuck in the 80's-
