Trying to isolate a leak on d16z6
I know without you guys being here its kinda hard to help me pinpoint the leak but. I have been trying to figure this out for 2 months now. If I wasn't saving up for my swap I would pull the engine out and just go back through everything but this is my daily, I didn't build the engine but it was built a few months before I got the car, but the guy took shortcuts when it came to gaskets.
I am getting oil mostly on the topside of my tranny and down the back of the engine. I thought initially valve cover gasket so I replaced that no change
Then I noticed the oil seemed to be coming mostly from around the area of the dizzy so I pulled it out and replaced that o ring.
I also see they used liquid gasket instead of oem gasket around the vtec solenoid. I am shooting with the possibility of something else that i don't know about.
About a month ago I was doing some spirited driving, had my hood off at the time and all of the sudden my oil cap shot off and made a pop noise as it went flying away got a new one and checked my pcv valve and replaced it since it was a cheap part.
Well today I noticed there was some oil on the header right where the dip stick is at. I also noticed some oil sitting around the gasket of the header but not like its coming through exhaust more on the outside but the gap in between the valve cover and header is free of oil.. The oil is also on the backside of the block.
I am very confused at this point ive tried washing the engine with degreaser about 3 times to get a general idea of where its coming from but im still stumped at this point
