- Sat Jun 16, 2012 12:52 am
#308426
Need some insight and input.
I have a d16y8 with 14b turbo setup. I drove the car about a month ago without issue. I parked it to put on my coil over system, HID retrofit, and powder coat my valve cover. Well after putting the valve cover back on (all new gaskets) to turn it around to align my HID's the car began to idle rough upon start. It will stutter until about 2.5k then level out. I have since replaced my plug wires with NGK and plug with bkre7's gapped to .30. I also changed my distributor and rotor to no avail. My next step is to vacuum test it.
Anyone have any insight? I am trying to get ready for a local car show and this just seems to be my luck.
thanks!
thanks!
Frustration is setting in. Still have to leak test it. Still has a rough idle and smells of fuel out of the exhaust....
