- Fri Oct 19, 2012 6:05 am
#318204
ok so i had a blown head gasket i replaced it put everything back started car drove it and noticed the timing belt was to loose so i tried to tightin it up a little more and now my timing is so messed up..can anyone tell me how to reset the timing car wont start..94/dx/d15b7...Do I set cam to (up)tdc then put crank to red mark then remove distributor cap and point the rotary button to the #1wire???
THANK YOU IN ADVANCE!!!
