- Wed Oct 24, 2012 3:30 am
#318527
I have a '92 hatch with a D16A6 block, D16Z6 head. Has a P05 Ecu. The car ran great when I shut it down and an hour later I went to fire it up and it would turn over but not fire.
My fuel pump doesn't turn on with the key before the motor turns over. So I switched out the 7-pin relay under the steering collumn, under the dash by the fush panel. I'm not getting any spark so i swapped out the spark igniter inside the distributor with a working one and the car tried to fire so I used a jumper wire to bypass the relay for the fuel pump and it started up but while it was running I pulled the jumper wire out and the car died because the fuel pump wasn't on. I repeated the same process of jumping the wire and it won't start at all.
What is it going to take to make this thing run?
Thanks for the help.
