- Mon Dec 10, 2012 12:45 am
#321911
does any one know if a crank shaft from a bigger motor would fit in my D13B2. I'm fairly sure the bore diameter is the same in most of the D series. I'm also interested to know if I can put a fuel injected head on it.
few specs:
displacement: 1,343 cc (82.0 cu in)
Bore and Stroke: 75.0 mm × 76.0 mm (2.95 in × 2.99 in)
Compression: 9:1
Power: 75 PS (55 kW; 74 hp) at 6,300 rpm[1]
Torque: 102 N·m (10.4 kg·m; 75 lb·ft) at 3,100 rpm[1]
Valvetrain: SOHC, four valves per cylinder
Cam Gear: 38 teeth
Piston Code: PM1G
Head Code: PM3
Fuel Control: Single electronic carburettor PGM-CARB
ECU: P01 OBD-0
Any help would be fantastic, even if you know any other way I might get power.
few specs:
Compression: 9:1
Cam Gear: 38 teeth
Piston Code: PM1G
Head Code: PM3
ECU: P01 OBD-0
