- Wed Jan 16, 2013 12:43 am
#324201
i own a 92 vx hatch the owner before me dropped a jdm d15b single stage vtec engine and had a po8 intake put in and had a virgin p06 ecu in it ranv kinda of shity had low bumpy idle and would run kinda boggy under 4000 and it had no bulb in the check engine light
since then i have done the followin
- i had problems with dizzy and replaced it
-converted the 5 wire o2 sensor to a 4 wire bosh o2 sesnor and this help with pulling at 4000 rpms thing and helped steady it out throughout the rpm range
- then converted the ecu to vtec and chipped it (this was about only two days after converting the o2 sensor) and had xenocron put a p08 basemap loaded on the chip after doing this it ran FUCKING AMAZINGit even idled perfect for about a day and a half
on the way to work i kinda noticed sometimes it would have a weird throttle repsonse barely even noticeble didnt think anything of it then on my way home from just as i was gettin close to home (its about a 16 mile drive to work) i would be holding the pedal steady and would miss it feel like someone took my foot off the gas for 1.5 secons then put back on was getting pretty bad as i got home then on my way to work i started to notice it again an was stopped at a red light and went to take off and im not sure if it was me not giving enough gas or it was really boggy but it stalled i started up then then tride to take off really boggy and ENGINE LACKED ALL POWER
and pulled over to the walgreens parking lot didnt have any tools on me just couldnt do nothing so i decided to put my hazards on and limp home ( i know not the brightest idea)
- after that i decided i needed to hook up the bulb on my check engine light so i did and no check engine light
-decided to start it up and drive around again to see how it is now that its sat drive around ran perfect and would get up to around op temp (driving for like 5 minutes) and would do that same missing kind of thing i explained
-now it idles high when started at about 2k then would drive around run good and about the same time the idle would find its way back down it would start missing as described earlier
-aslo started to develop lumpy idle as well
-now i have replaced my fuel pump (sifter and strainer as well) no difference
-replaced spark plugs and spark plug wires no difference
-decided to bleed coolant just casue the temperture got at abou 3/8 on the gauge after finished when to try and drive engine had no power again like what happened earlier
now im here typing hoping someone has an idea whats going on i tried to include as much as i can feel free to offer suggestion and ask question will be putting up pics of my bay later
oh well looks like imma put an order in for neptune
