Not able to remove valve cover bolts
As the title implies I am not able to remove the valve cover bolts. I don't mean loosen them, I mean actually remove them once the cover is off. I had my front right cover bolt strip but I can't take them out, they seem to have a what I can describe as a permanent washer. I'm not sure if that's to keep them from falling out once the cover is removed? I wanted to also replace the cover bolt grommets but I couldn't take off the bolts to do so..
Anyone ever seen that? If needed I could post a picture tomorrow. Thanks
