- Fri Oct 25, 2013 8:39 pm
#338060
I have civic with a d16z6 and it has the check eng light on cuz it does not have the censor that goes on the cat. My car stars and run fine but the water comes out on the reserboid water. I have to check and put water on the car evertime that i have to used. What could it be. Help plis.
jvc7065 wrote:I have civic with a d16z6 and it has the check eng light on cuz it does not have the censor that goes on the cat. My car stars and run fine but the water comes out on the reserboid water. I have to check and put water on the car evertime that i have to used. What could it be. Help plis.
Okay so I am going to take a crack at this and say that your trying to get across that you do not have an O2 Sensor?!
Are you saying that you have coolant coming out of your "reservoir tank"?!
and if you are filling your car up with coolant every time you get in your car there are some issues that need to be addressed.
Is that what you are trying to get across?!
