- Wed Oct 30, 2013 3:38 am
#338184
Hi: I'm new here. I've used the forum for information to do my first head gasket job and it's been really helpful. The car is 92 civic hatch D15B8 about 130,000. Everything is put back together, but I have one issue I want to check in on before I crank it over. I had trouble locating the timing belt tension adjust bolt that is right above the crank pully, (because I'm lame), so I just slipped the belt off as it wasn't that tight. I marked the belt and the cam gear first, so I would make sure to put them back right. I couldn't get the belt back on. Then I located the bolt, right where it's supposed to be under the little black cover. I loosened that. Then I put the crank pully and the cam gear both to the timing marks provided (white mark lined up on the crank shaft and lower line on the cam gear lined up with the little plastic pointer on the inner timing cover) and put the belt back on. I then followed the instructions in the manual I have for retensioning the belt, which is 1/4 turn counter clockwise (3 teeth on the cam gear) and re-tightened the tension adjustment locking bolt.
Question. Now the lower white timing mark is not lined up, when the cam gear is at TDC. It's about one inch or so to the left of the reference marks. That doesn't seem right. The only thing I can figure I might have done wrong is that I didn't loosen the crankshaft pully at any point. The belt also seems fairly loose, but I have no idea how tight it is supposed to be. So, what's up? did I screw up, or is this normal? The manual seemed pretty clear that this is the procedure, but the whole procedure was timing belt replacement with full removal of the crank pully etc... Sorry, I'm a newb. I'm reasonably mechanically inclined, but there is no substitute for experience. Any help appreciated, so I don't bend any valves.
TIA
TIA
