- Mon Jan 20, 2014 3:55 am
#341568
Hey guys just want to get some confirmation on this. Was looking through a lot of searches and not all the information could be found in one search. Mechanically I'm able, but I'm not too familiar with Honda specs.
I have a 1995 Civic DX Sedan with a automatic transmission. The motor is pretty much shot. My sister blew a radiator hose and kept driving until the car overheated. Engine is not running too well now.
D15B7 non vtec engine with 102 HP.
So I'm looking into a possible engine swap that's easy and gives me a little more power. I have to keep the transmission an automatic so my 2 sisters can drive it. That means, no B-Series. I came up with these 2:
D16Z6
92-95 Civic Ex/Si vtec with 125 HP. OBD1 ECU.
Since both engines are from the same cars this should be a direct swap. Other than wiring the vtec solenoid and using a P28 ECU.
Is there anything else I'm missing here?
D16Y8
96-00 Civic EX vtec with 127 HP. OBD2 ECU.
From what I gather this is "pretty much" a direct swap as well. Again, other than wiring the vtec solenoid and P28 ECU. I read somewhere about differences in knock sensor and MAP sensor? I read in most posts that some plugs/wire don't need to be hooked up or hoses don't need to be connect for the engine to run. But I want to make sure Everything is able to be plugged up and look as stock as possible. I'm just not sure on the little, if any, differences this engine might have with the 92-95 chassis.
Another concern I have is the car's ability to pass California smog with these swaps. My smog guy won't dock me on the visual, but will charge extra for the sniffer. As long as I connect everything on the D16Z6, it should have no problems passing other than the visuals correct? It's the D16Y8 I'm more questionable about because I'm not sure of the slight differences it might have. I rather try to pay the regular smog fee, rather than the 150% mark up.
I think that's everything... Let me know if I missed anything. And please add any comments that will help.
Thanks.
D16Z6
D16Y8
Thanks.
1995 Honda Civic DX Sedan
