Page 1 of 2
Valve Cover Issue
Tue Mar 18, 2014 12:51 am
by 95egcoupenj
I have a 1995 Coupe with a D15B7 and I have now replace my valve cover 3 times and still getting oil in the spark plug wells numbers 1 & 2 more in 1 and i have used ultrablack and still get the same result any suggestions???????
Tue Mar 18, 2014 2:15 am
Did you replace the 4 donut gaskets when you replaced the valve cover gasket?
Tue Mar 18, 2014 3:10 am
by TrailerTrash
they can be a real bitch to do correctly. the slightest little mistake and they will leak
Tue Mar 18, 2014 3:53 pm
by brandoff88
indeed, I had to chisel mine out carefully with a mallet and screwdriver with cloth on end...putting em in was a lot easier..but still a pain
Tue Mar 18, 2014 9:09 pm
by 95egcoupenj
i have replaced the doughnut gaskets, i just dont see how if even my master tech assisted me it still be put on wrong
Tue Mar 18, 2014 9:55 pm
by TrailerTrash
did you give them a light coat of oil before you reinstalled the cam cover?
some people will disagree with this but i see it the same as an oil filter. a real light coat of oil over the seal/gasket does the trick
Tue Mar 18, 2014 10:35 pm
by 95egcoupenj
i did indeed apply a light coat of oil, is it possible the valve cover itself is bad
Wed Mar 19, 2014 1:03 am
by eg84dr
it is posible that it is warped real bad
Wed Mar 19, 2014 3:08 am
by TrailerTrash
are you tightening them to the right in/lb? and in the correct sequence?
Wed Mar 19, 2014 3:58 pm
by brandoff88
you know I bent my first one up really bad...had weird idle but no oil in the plugs...that's very strange...
Thu Mar 20, 2014 2:37 pm
by HeikDiesel
TrailerTrash wrote:did you give them a light coat of oil before you reinstalled the cam cover?
I don't oil static seals. The only reason you put oil on a filter is you have to spin it on so you need some type of lubrication when you twist that seal on tight.
Thu Mar 20, 2014 3:51 pm
by eg84dr
there are four seals under the rocker assembly
you could put a thousand new donut gaskets and valve cover gaskets and it would never fix the issue
heres a pretty good rebuild link on d-series it shows the gaskets im talking about underneath the rocker assembly
http://www.d-series.org/forums/diy-forum/121481-diy-kitchen-counter-top-head-rebuild.html
hope this helps and isn't too confusing
Thu Mar 20, 2014 8:16 pm
by TrailerTrash
HeikDiesel wrote:TrailerTrash wrote:did you give them a light coat of oil before you reinstalled the cam cover?
ive never had a seal leak after putting oil on it.
not trying to argue im just saying. thats why i said some will disagree
Fri Mar 21, 2014 1:06 pm
by HeikDiesel
TrailerTrash wrote:HeikDiesel wrote:TrailerTrash wrote:did you give them a light coat of oil before you reinstalled the cam cover?
I always welcome new ways to do things. Only downfall I can see in it is if you worked for a shop and did that for a customer car some might weep a little giving off the appearance of a leak.
Sat Mar 22, 2014 12:48 am
by TrailerTrash
that is true. good thing i only use my subpar skills on my own heaps of shit
