- Sat Jun 14, 2014 8:30 pm
#346447
I recently acquired a 1992 civic sedan with d15b7. I had a look at the timing belt when I was fixing a leaky valve cover and it's cracked so I'm going to change it. I've read about all the marks and how to line it up with #1 cylinder at tdc with the crank marks NO PROBLEM. The problem I have is that the top marks are off about 1/4 to 1/2 inch from the upper cam marks. Now is this because of the timing belt stretching? Or did it skip a tooth at some point. And since it is off the marks should I put the new one on and line up all the marks where they should be. it ran fine before I started all this. Thanks for any help..
1992 Civic Sedan
