- Tue Jan 20, 2015 2:58 pm
#351172
Because my car was idleing funny and when i took of a stop it would sound like it was choking or was misfiring.I recently changed my tps sensor /and cleaned the throttle body with carb cleaner and sprayed with air to dry it up,when i floor it (step on the gas hard)the engine light comes on when i turn the car off and turn it on again the engine light goes away but if i step on the gas again it happens again. I noticed an improvement on acceleration and idle is ok but it could be better and sound smoother (how do i adjust the idle?) Also now i have to push my shifter button a few times or wait about 30 sec. Before i can change gears, i think this may be due to me undoing the metal cables that go to the throttle body (how do i fix that?) , is also still doin the chocking/misfiring sound on take off sometimes. Ok that sounds like thats enough for now im sure most people didntt make it this far.If you do have 30 sec and know how to help me or can point me in the right direction i appreciate all the help
Make sure the TPS is installed correctly before continuing with this process. You want to make sure the small tab on the TPS sensor is installed between the notch on the throttle body itself so that it moves with the throttle plate. Once you have checked this continue to the calibration process. (Tip: sometimes it is easier to remove the throttle from the motor to install the TPS, the throttle gasket is only a couple dollars and you'll lose a tiny bit of coolant removing the fast idle lines)
Now the important part.
The throttle position sensor has three wire. A 5 volt signal from the ECU, a ground, and a signal wire. We are concerned with the signal wire in this case. The signal wire will be the middle wire in the 3 pin connector.You will need a voltmeter and a back tap probe (A very thin attachment to stick into the back of the wiring with the sensor connected http://www.olct.co/electronic-specialties/flexible-back-probe-pins-1 <I haven't ordered from this site this is just to show what the tool is.)
If you don't have the tool you can always strip back a small section of wire and measure from there just be sure to heatshrink or tape over the exposed section when you're done.
First you want to turn the key to on without starting the car then look at your voltage measurement with the throttle shut it should be around 0.49 volts. If not slightly loosen the TPS and move it until you get as close as possible to 0.49 volts.
Second once you have the 0.49 volts closed reading tighten the TPS and then measure the voltage with the throttle wide open. It should read 4.5volts or higher. The factory ECU recognized 4.5volts as 90% throttle. If it does not come out correct usually its a faulty TPS.
Also you need to reinstall the two throttle cables back to the throttle body if you have that second one uninstalled that goes to your automatic transmission it will not function properly.
Hope this helps.
Instagram:
https://instagram.com/enjoymotorsports
Website:
https://enjoymotorsports.com
Instagram:
Website:
