Z6 skunk2 intake manifold
Sun Apr 12, 2015 4:21 am
by slow4dr
I just bought a skunk2 pro series intake manifold from a friend tonight (4/11/15) however it didn't have the throttle body, my question is has anyone here used this intake manifold with a oem throttle body? If so it'll only be until I save up and buy a matching skunk2 throttle body.
Thanks for any and all input
Sun Apr 12, 2015 10:58 am
by EconoBox
Any D/B series throttle body OEM of aftermarket will fit that manifold. The only thing you have to be careful of is using a throttle body with a bore bigger than the bore of the manifold.
Sun Apr 12, 2015 1:38 pm
by slow4dr
Ok thank you
Sun Apr 12, 2015 4:29 pm
by blk92hb
the manifold can be ported. if you do get a larger tb than the manifold then you can gasket match the manifold so it will flow correctly
Sun Apr 12, 2015 9:27 pm
by slow4dr
I knew it could be ported. I just read on skunk2 's website that the oem throttle body couldn't be used but also read it could on other sites and was confused.
I'm only planning on a 66-68 mm throttle body so shouldn't be to big for it
