F23A1 5speed swapped civic
Ok everyone, well I have been contemplating doing something a little different in my EG coupe. I came across a wrecked 1999 Honda Accord EX 5 speed on craigslist, the owner was selling the whole engine, tranny, shift linkage and shifter box for $250. I first thought this was too good to be true, so I met the seller, engine cranked on first try and idled and ran fine. So I bought it. I did a lot of research into swapping this into the EG civic, and a lot of the research pointed to the fact it is basically like a H22 swap. And it really is. I am making this write up because it seems there is a lot of scattered info on how to do this particular swap, so I want to condense it and help anyone else who wants to do this.
So my 1995 civic dx is pretty stock, except for a y8 intake manifold, and y8 header. The d15b7 still had a lot of life left in her, even with over 200,000 miles on her.
So what you will need to put a f23a1 into a 92-95 EG civic.
-F23a1 5 speed swap, shifter cables, shifter box
-F23a1 accord halfshaft (female)
-F23A1 passenger side inner cv axle cup
-90-93 Accord dx/lx manual rear T-bracket
-90-93 Accord dx/lx manual driver side engine post
-90-93 Acura Integra cv axles
-H22 into EG mounts( Hasport, Avid, etc) I used Avid billet aluminum mounts
-Smaller belt to just go around alternator and crank (I just measured with string and took the string to Advance Auto and found a belt the right length)
**EXTRA ITEMS**
-oil, tranny fluid, misc. bolts, stuff like that.
-Fuel hoses, vacuum hoses, slim fan.
**EXTRA ITEMS**
