- Thu Jan 27, 2011 11:18 am
#235733
ive done some searching but it only talks about white civics and stuff so heres my question i just swapped on ls motor in my civic for another and after we got it all back together and running i tooks some coners hard like i norm,ally do and the car smokes like a bat out of hell i can figure it out i want to prolong the chance of having to change the head gasket but i dont think it is the head gasket because there is no oil in the cooanl and there is no coolant in the oil and all my other gearhead buddies say its not the headgasket When i bough the other ls motor it had just been rebuilt by a local shop by were i live and they did all the seal and everything and it has had everything changed so i don no hwtas wrong. i just changed the intake manifold gasket and throttle body gasket because i thought thats were coolant was sneaking through and it still does it and could it also be that they didnt torque the head down properly and there is coolant going through there
thanks any help wou;d be appreciated
and one more thing it doesnt smoke profusely itll stutter and then itll smoke then stop just for about 3 seconds so thats why i dont think its the head gasket
. I'd say he went the cheap easy route. Which is re-useing the headstuds and after torquing to the amount called for never give them an extra 1/4 turn to take in account for used studs. I did before and they worked fine. How bad was your valve lash? Just curious
