- Fri Feb 25, 2011 5:46 am
#240833
I have a hydro LS trans with 3rd and 4th gear issues, I also have a hydro b16 trans with a cracked case, my question is can the b16 gears go into the LS case with no problems? i have searched around and have never found a definate answer. any help will be greatly appreciated
- Fri Feb 25, 2011 5:50 am
#240834
Posted in the wrong section, Should be under transmission.
To answer your question though, Yes you can move all the gears from the Hydro B16 transmission and put them in a Hydro LS Transmission casing.
If you do freeway driving you might wanna swap out B16 5th for LS 5th.
