- Wed Jan 18, 2012 4:18 pm
#290818
This is what I'm going to gather up before i do the swap. Let me know if i need anything else. Motor, LSD Hydraulic Tranny (S80), ECU (P73), Axles with Half Shaft, Shift Linkage, Hasport Mounts, Alternator, Starter, Clutch, Flywheel, Intake Manifold, Exhaust Manifold, Fuel Rail, Injectors, Distributor, Engine Harness, All Sensors(Im sure this will come with the motor), and conversion harness. This will all be going into a 93' civic hatchback EG. So its obd1. Now my main concern is the obd1 to obd2 conversion. From what i understand i should just be able to plug and play with the hasport conversion wiring. Also from what i have read, i should be able to use the civic engine harness, but the motor comes with the b18 engine harness so either way i got two harnesses so which should i use? Thanks in advanced for any info.
|^^^^^^^^^^^\||____
| The STFU Truck |||""'|""\__,_
| _____________ l||__|__|__|)
Panda Crew Member #24
Coupe Crew #9
Team XXX Racing
Coupe Crew #9
Team XXX Racing
