- Wed Apr 21, 2010 3:13 am
#188900
I have the same problem accept when my vtec wont kick int he engine sounds different like its not as loud as it should be. I checked all the wires nd I think one wire was not spliced all he way so fixed that and took it for a spin nd vtec was working good. Also saw that I was low on coolant so filled it up. Tyanx for all the good info Guys. Anyone know why it would idle low tho? Only happens when engine is hot.
get your car to operating temp, - drive around for a bit - , once the car is warm, pop the hood, on the throttle body there is an adjustment screw, turn it to the left till the idle goes up... i think its the left...
try it, either way the idle will go down or up,
check timing
check your ecu... any codes?? ive personally had an ecu that would not throw any codes, and my car idled low, i replaced it with a spare and it ran perfect, could be the ecu...
car trouble always suck ass
"smoke me a kipper ill be back before breakfast" - ace rimmer
