- Tue Nov 17, 2009 2:50 am
#156878
ok i changed my plugs and wires.... both oem from the dealership... ok so it ran fine ...then half way to waco it started bogging down and taking forever to hit vtec range rpm's. . you could here it in the exhaust and could feel the car sputtering and jerking. i also changed the fuel filter, i did it right no leaks also form the dealer and also replaced the washers that are in there..... i did the wires one at a time matching up the lengths ... the car def sputters and sounds like it boggs down ... any suggestions ... should i try the dizzy? advance or retard it ? i thought it was bad gas but i already drained that tank and put super in from another station... injectors , fuel pump ?
#7 member of the Panda Crew ..
black and white keep it tight!!!!!!
