- Fri Aug 06, 2010 3:16 pm
#207674
I found a b18b block at a junk yard, an i was wondering if i put a vtec head with high compression what whp would i be capable of?
I'm guessing you know it's not as simple as slapping the head on the block and bam you're making power. Based on your post count, you have probably seen the numerous LS/VTEC threads on this site, and probably across the interzweb.
