- Tue Mar 29, 2011 10:51 pm
#247009
After I changed the head gasket on my B18A1 in my del sol the check engine light turned on and the car idles poorly and I keep putting coolant into the reservoir but it keeps going empty any ideas? I put the head gasket on correctly and I tightened down all bolt to specs, all hoses and sensors seem to be in place and new spark plugs and newer wires. The timing may be off or may have something to do with the new header or new NGK spark plugs.
- Wed Mar 30, 2011 1:06 am
#247030
why was the gasket changed? did it blow? did the car overheat? was the block decked?
have you checked what CEL code your throwing?
