Adjusted Timing last night..(SOLVED)
So heres a long story, my previous problem with my b16 was the ckp sensor which is fixed now. now i have backfiring/chugging/hesitating/rough idle issues and i have to like ride the clutch when taking off to prevent stalling and chugging. i used a timing light to adjust my timing, i think my ignition timing was off by 6-10 degrees of the red mark, so around 6-10 btdc?? but anyways so i went to adjust it to specs, right on the red mark, i had moved the distributor almost all the way advanced. but when that was done, my car still ran the same. and it made these weird random hiccups, i dont kno how to explain it. i was shooting the light while it was hiccuping and it appears to affect my ignition timing like about a degree or two then goes back to the red mark. i had it running for a good 15- 20 mins to warm up, so after that i started to rev it on the throttle cable, just little revs, and it would choke and almost die and backfires. if i slowly rev it, like really slow, it doesnt back fire or anything, but if i rev a little real quick, like a tap it would choke and backfire. and then all of a sudden it backfired hard enough to stall my car.
i have no clue what the chugging means when idling though, never happened before.
anyone know what it could be?
im gonna try again tonight or so and really fuck with it.
im getting tired of getting the one problem after another problem solve..sigh
oh yea and no CEL, and another thing is i did forget to jump the connector, but i turned off the engine, jumped it and then turned it back on.
maybe im not doing the ignition adjustment right
i dont care as long as my shits up and running now.
