usdm B16A head with B16B block...
i have been searching for this alot i found out its wasting of money then i thought of going to Compression Calculator at http://www.c-speedracing.com/howto/comp ... mpcalc.php and see what it has to say about it
so here the thing
stock USDM b16a compression: 10.2:1
stock USDM b16a with 2 layer head gasket comp: 10.5:1
stock USDM b16a head with B16B block with 3 layer gasket: 10.8:1
stock USDM b16a head with B16B block with 2 layer gasket: 11.1:1
i have calculated the amount of money for rebuilding the existing b16a block was about 1250$ and i found a fresh rebuilt B16B block (built by spoon japan) for the same amount waiting for the reply from my freind to know what comp and bore it has.
now if its complete stock should i go with it and get the 2 layer gasket or it wont be safe to run this application or better stick with the b16a block
so here the thing
