Idle RPM surge from 1000 - 1500, need some help
My B16A motor is pretty much running perfectly other than the odd idle problem I have when in neutral...
This only happens when my car has warmed up to its optimal temperature, then when the clutch is depressed or when in neutral, the RPM surges from 1000 - 1500.
I have already cleaned my IACV and took apart my FITV and cleaned that up really nice aswell. Both of those showed no luck with my situation, could it be something else? Myabe the Dizzy or something?
Here is a video of what is happening, sorry for the poor quality in advance, my phone sucks haha! From the start of the video, I am driving normally, then I put the car into neutral and pull over to let the car idle. This is when the RPM surges, I do a close up closer to the end of the gauge.
(NOTE: My temp gauge is hooked up with a different gauge on my pillar, so ignor the s2k temp gauge, that is still under work)
Any insight will be greatly appreciated!!! Thanks in advanced!
