- Wed Jan 30, 2013 1:47 am
#325220
Hey can someone give the torque specs for a 99 b18b1 I can't find the specs for the crank caps or the rod caps
B18B1
NON-VTEC
Found in:
1994–2001 Honda Integra "RS/LS/GS/SE/(GSI Australia)" (DC4/DB7)
1992–1996 JDM Honda Domani (MA5)
1993–1994 JDM Honda Inta (DB7)
1996–1999 JDM Honda Orthia (EL1)
Displacement: 1,834 cc (111.9 cu in)
Compression: 9.2:1
Bore: 81 mm (3.2 in)
Stroke: 89 mm (3.5 in)
Rod Length: 137.01 mm (5.394")
Rod/Stroke Ratio: 1.54
Power: 142 bhp (106 kW) @ 6300 rpm & 127 lb·ft (172 N·m) @ 5200 rpm
Redline: 6800 rpm (7200 rpm on JDM Domani)
Rev Limit: 7200 rpm
Transmission: Y80/S80
JDM version is marked B18B on the block without any number.
JDM version has a compression 9.4:1 where the usdm version is 9.2:1.
JDM version has a higher compression ratio which results in higher hp and tq levels than the usdm version.
http://en.wikipedia.org/wiki/Honda_B_engine#B18B1
