- Fri Feb 22, 2013 3:42 pm
#327062
ok guys i am running a poor mans type r set up build block 12.7.1 cp ratio been driving her for 2 years wit out a prob got it tuned at 197 on s300 and i have ihe on it as well as the 81.5 pistons and all that jazz but i have a fairly stock head i mean stock inatake manny, tb , gsr cams, gsr vavle but 3 angle vavle job and i am looking to make a bit more power... i have the chace to get a skunk2 70mm tb and inatke mannny for it will this add big gains in horse power do to my cp ratio or will i really not feel the diffrence ??? i should not need to get my car retuned right i was told buy my tunner i will be fine not to re tune just yet..any input will help
- Fri Feb 22, 2013 5:59 pm
#327073
Its worthwhile if you upgrade cams too.. You'll actually lose bottom end power if you just throw on tb and intake
- Fri Feb 22, 2013 8:35 pm
#327082
I agree with Juice on this.
It would be wise to consider getting cams as well as upgrading the TB+Intake Mani.
JUICE wrote:Its worthwhile if you upgrade cams too.. You'll actually lose bottom end power if you just throw on tb and intake
|^^^^^^^^^^^\||____
| The STFU Truck |||""'|""\__,_
| _____________ l||__|__|__|)
Panda Crew Member #24
Coupe Crew #9
Team XXX Racing
Coupe Crew #9
Team XXX Racing
- Sun Feb 24, 2013 6:41 am
#327189
Can you please define your setup? I always thought poorman's R involves at least R-cams?? Have you made 197 at the wheels with GSR cams?
If you are running GSR cams, the biggest upgrade for you is typeR cams, and I'd definitely go that route for the same money which you will pay for 70mm TB and intake manny. B16 intake manny is not that bad really, especially if you rev to about 8k rpm (which you should bearing in mind the fact that you're not making power there with these GSR cams).
In order to survive you've got to earn your respect
The only lessons that you learn are from things that you regret
- Mon Feb 25, 2013 4:44 am
#327226
yup yup gsr cam lol sad face lol my set up is weico pistons 81.5mm 12,7,1 cp ratio , eagel rods gsr crank micro pholished fairly basic
as for the head its off a si b16a2 stock intake manny tb, 3 angle vavle job on stock vavle ferra bronze vavle guides, new nsx lma,s head has been milled block has been decked and all i had was gsr cams lol here is the dyno vid vtec cracks hard
http://www.facebook.com/home.php#!/phot ... =2&theater
copy and paste hole link
- Mon Feb 25, 2013 12:59 pm
#327245
ITR cams should be ran with dual springs tho.. Not sure about NA, but I got a buddy who put ITR cams in his stock b16 head boosted setup and he ran into valve float issues..
- Mon Feb 25, 2013 5:43 pm
#327254
Weak springs cause valve float. As long as they're sealing good, you're valves should be alright.
- Mon Feb 25, 2013 11:10 pm
#327284
Yes Supertech springs work with pro series cams. As long as you buy the correct ones.
To stiff of a spring and you can run into accelerated wear on the rocker arms and/or the cams.
Supertech offers two sets of springs for the b-vtec heads. You'll want the ones with lower seat pressure. PN SPR-H1002D.
http://www.supertechperformance.com/cat-ivalves?id=2
92dxeg wrote:i have type r springs in my car but i would like to upgrade to super tech i think would that b able to suport the pro1 cam
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
