- Tue Jan 21, 2014 8:10 am
#341626
I'm pretty sure that this has been covered already, but I have a problem of my valve cover rubbing on the hood (top right and lower middle of valve cover). It is rubbing on areas where there is no webbing on the hood. I've been hearing about a washer trick, but no one has yet to explain it or post pics. Not really looking into gappin the hood. My hatch has a gsr swap.
Anyways, I just keep some stainless washer underneath my hasport mounts and it solved the issue.
This is the only picture I can find right now, there may be more in my build thread if you want to take a look.
If you look closely you can see the washers underneath the mount. I have 6 total on that side. I use 9 for transmission side.
I <3 my Honda.
>Two.Zero< Garrett 60-1
@cdmtyper
My Build Thread
@cdmtyper
My Build Thread
