timing belt adjustment bolt help
PostPosted: Sun Mar 09, 2014 1:27 pm
by EG6_rugby
im stuck. My new timing belt is to tight and i can not get the adjustment bolt to loosen, am i missing something? please help
PostPosted: Mon Mar 10, 2014 12:55 am
You're sure it's the correct belt? Are you running a mini-me head/block combo?
You can count the teeth on your old and new belt to be sure it's the right one.
Edit, nevermind I just noticed it was posted in B series, so not a mini-me issue.
PostPosted: Mon Mar 10, 2014 2:09 am
by cleanb18eg
Are you talking about the tensioner bolt? Should come loose fairly easy as they are only torqued to ~ 40 ft/lbs. If your having trouble spray a little anti-seize but try not to get any on the belt.
PostPosted: Mon Mar 10, 2014 7:56 pm
by EG6_rugby
teal_dx wrote:You're sure it's the correct belt? Are you running a mini-me head/block combo?
:thumb: no worries thanks for replying.
I did the anti seize but no joy and im in the middle of a move so whole project just got put on hold. thanks for the input
PostPosted: Tue Apr 01, 2014 5:23 am
by PirateEG
I did the belt on my b16 this past summer. I believe I had minor issues with that bolt as well. What can help a bolt that is stuck like that, besides some sort of liquid wrench/anti-sieze, is "bouncing the bolt". What I mean is, repeated pressure to loosening the bolt. Don't just pry as hard as you can; apply pressure, let off, apply pressure, let off, etc.
That helped me, specifically with the crank bolt. I was prying and prying, and bent the extension pipe i was using; I gave up for a while, but once I "bounced the bolt" it finally broke loose.
hope this helps.
PostPosted: Fri Apr 11, 2014 12:27 pm
by EG6_rugby
PirateEG wrote:I did the belt on my b16 this past summer. I believe I had minor issues with that bolt as well. What can help a bolt that is stuck like that, besides some sort of liquid wrench/anti-sieze, is "bouncing the bolt". What I mean is, repeated pressure to loosening the bolt. Don't just pry as hard as you can; apply pressure, let off, apply pressure, let off, etc.
hope this helps.
I will give that a try. Thanks.... Move is all finished in to my new house. getting my new garage in order The hatch will look like a micro-machine in the garage. garage is huge almost 900 sq ft.
PostPosted: Sat Apr 12, 2014 10:18 pm
by brandoff88
what I usually do is take a rubber mallet and hold the ratchet tight, and give it a few mid power whacks to start breaking it loose, try to ratchet it, if not give a few more good whacks, keep repeating until it comes loose enough to use your ratchet, sometimes also wd-40 penetrant not the regular stuff, can help as well
