b20b swap parts and wire harness questions.
sup everybody, well, im swaping a b20b into my 94 civic sedan that had a d16z6 in it. now I know I can use the d16 wire harness for the b20b(97), but I noticed that on the LS intake manifold, that it doesn't have as many sensor plugs as the d16 intake manifold had. so does that mean that I would have to leave a electrical connector on the wire harness unplugged and zip tied to itself? what other connectors am I not going to use? phearable. net told me to just leave the vtec sensors unplugged (duh).
now, I have the the motor, gsr trans, shift linkage, t bracket, LS integra driver side motor mount and bracket, fidanza flywheel and exedy stage 2 clutch kit. I KNOW I need a p75 ecu or have phearable chip my p28 ecu, but am I missing anything else needed for this swap?
I read that I will need a LS upper radiator hose, can anyone confirm that?
lastly, what brackets do I need to retain the power steering and AC?
I do a lot of my own research, n some of this info is probly out there, but I need a clear answer. thanks
