- Sat Feb 02, 2013 4:24 am
#325460
im ase certified and a machinest, but i do know that selling a "refurbished" cat is illegal,
ill look up the federal law code for you if i have to
just go to your local exhuast shop and purchase one do it right the first time
and btw "high flow" cats are bullshit same junk just little bit bigger diameter in the pipe
if you want a high flow cat just buy a 3" exhaust with resonators, so its not all rice and loud
my kids godfather is state patorl and he gives the biggest ticket he can for loud exhaust our county will get rid of your ticket if you show proof of recipt that you had your exhaust system changed to one that has resonators not a fart can
apexi, skunk2, greddy
all give our hondas a bad name.....
just get a 3" custom exhaust thats quiet. i have one on my k and i still make power, it flows just fine.
at the end of the day if you look at the basic mechanics of an engine even adding bigger cams changing the compression ratio you only need a 3" that flows deent its not how fast you can dump it out its how fast you can pull air in, the exhaust allways pushes itself out like a drain in a sink.
if your only pushing in 2" of water in, and pumping out into a 3" drain is a cat and resonators really going to restrict flow???
hope this helps out. maybe i should have put this in the exhuast section or engine section
ill post up the math we use when building engines and such even though the computers do it anyway
"smoke me a kipper ill be back before breakfast" - ace rimmer
