Appearance, Paint & Body Work
By ShEfA
#108432 Hi to all of you :)
The weather is warming up and I am starting the little reapirs on my hatch. The thing I want to do is to fix the doors. I don't know if anyone has this problem, but I do, and it is the following:
When I open the door it drops... It sounds bad, although it isn't, because I can't explain in well in English. It doesn't drop on the ground, it just drops a few inches and when you close it, makes a very ugly sound, also the feeling is shitty.Once I opened a hatchback front door on another car, and it didn't drop, it was like heaven...
I don't know if you know what I tried to explain, but I did my best. Can you help me on this matter? What should I do, is this problem fixable, I heard it is. :)
Thank you in advance!
By Graham
#108433 Adjust your hinges and the door latch, you'll probably have to remove the wing to get access to the bolts for the door hinge
By ShEfA
#108482 The wing? You mean the fender?
By DontHateonEG8
#108523 probably replace them altogether, sofia is a pretty humid place so hinges probably are gone. try adjusting and lubing them first and if that problem is still there, than buy new ones.
By ShEfA
#108576 I have the car for a little over a year, it "lived" in Italy before that. How do you know what the weather is like here, have you been to Sofia? :)
Ok, so, I should take the "wing" off and see what to do by intuition?
By yashep
#108588 take the "wing"/fender off and just buy new hinges. it's the only way to fix this is, it has pieces of metal inside when they wear away with time. This happen to me and did everything I could to fix it and avoid buying new ones, ended up buying them and problem fixed. :thumb:
...Unless your hinges bolts are loose :?
By Graham
#108620 How does humidity affect hinges? :? they're bits of solid metal, just adjusting them will solve this problem im sure - i've had to hang my doors a few times and always been able to adjust them at the hinges fine
By Matt_hatch
#108694 when you open the door can you move it up & down??? if so the hinge pins are worn out, & will need to be replaced
By ShEfA
#108841 Unfortunatelly I can move the doors up and down :( I will take the wings down, and will try to fix the problem... If not working, then I am going to buy new ones... which probably will cost me around... 4000$ /the Honda dealer here in BG is a di*k :)
I will be very happy if Graham is right. So, Graham, can you tell me what exactly should I do, or it is easy? :)
By 93whiteeg
#109055 when i bought my car i had the same problem, i went to a body shop and the guy said all he had to do was to take the the little pin that lets the door not open too much. and in the hinge put a little metal thing that looks like a "c". he pulled the door up and wedge the little "c" in between the hinge. so he welded it in to place but making sure not to weld the hinge and the "c" cuz then you wont be able to close the door. it woked perfect.
By DontHateonEG8
#109066
Graham wrote:How does humidity affect hinges? :? they're bits of solid metal, just adjusting them will solve this problem im sure - i've had to hang my doors a few times and always been able to adjust them at the hinges fine
well, metal does rust in humid conditions, if lubrication is gone and bare metal is showing, rust can eat metal away.
ShEfA wrote:I have the car for a little over a year, it "lived" in Italy before that. How do you know what the weather is like here, have you been to Sofia? :)
no, always wanted to go there. but back when i lived in ukraine my moms sister would always go there for business related stuff. lol. but dude, i ever go we should meet up man!
By Graham
#109455 Take the wing/ fender off and you'll see 4 bolts that attach the hinges to the shell. Loosen them and lift the door slightly higher than it needs to be, tighten the bolts and see if it lines up better. Just keep adjusting it till you get it right
As for hinges rusting, theyre like 7mm or 8mm thick metal - no danger they'll rust away :lol:
By DontHateonEG8
#109503
i guess. but what if someone spilled vinegar-peroxide solution on it, huh? i mean shit happens :twisted: haha, jk.
By foru2nvy2
#109536 i had the same problem until yesterday i was at my cousins and we were looking at my car and told him about it he said its usually not the pins but the metal they bolt to cause if you have your door open and lean on it it will bend all we did was lift up on the door a couple times now it shuts like butter,now i keep forgetting and slam it shut,just remember not to lean or pull down on them when getting out
