matt is (eg6) wrote:not unless you like buying new tires all the time its negative camber and it wears out your tires quick
well if you get your car lowered like mine were camber is prety negative, just get an alignment. i drive the shit out of mine and been lowered for almost 2 months and i have seen no diff in wear in tires. just need the toe and caster to be in spec. then youl be fine.
