- Thu Nov 26, 2009 1:00 am
#158459
**GO TO PAGE 6 TURBO INSTALLED!!!**
so, I bought a pretty basic kit. its far from the best, but slightly better than your standard cheap ebay kit.
the plan is to keep the car running how it is till i get all the other components for boost (tapped oil pan,fuel management/components,etc. etc.)
since my motor its self is internally stock, we're not shootin for any crazy hp goals. gonna get it tuned to lowest psi possible to make around 200whp. the car will be used as a "nice day" cruiser and occasional drag strip assassin!
the kit itself isn't too bad. all the oil lines/fittings are Earls Performance, and the intercooler/manifold are better looking than most ebay kits. the charge pipes are mandrel bent and has the BOV flange. as i go, i'll upgrade parts on it as needed/wanted.
I need suggestions on what to do with the ECU(for tuning!). what are my options here for what i have in mind? do i need to look into bigger injectors? suggestions on any of the remaining components i need to buy are much welcome. remember, we're working with a stock B18B1 with a low-boost goal (6-7lbs).
the kit...
the kit...
i know that most of the d series hondas at least run around 11:0 in full boost but i'm sure some of that is a safety factor...
