- Sun Dec 20, 2009 5:54 am
#162981
Well ive taken out my power steering pump and would like to find a reservoir that will hook up to my rack so it doesn't run dry. Does anyone know where i can buy one of these?
- Mon Dec 21, 2009 10:24 pm
#163230
If you put a resevoir on your power steering rack like that it will blow all the fluid out of it. You drive for a little bit and gets hot and blows like a geyser all over the underside of your hood.
You need to let the fluid drain out and then squeeze a little more out by cranking the wheel each direction at least once. You don't want it bone-dry but you'll never get it bone-dry anyway. Then get like a clutch resevoir and drill a big hole through the cap. Then you'll need to rig up some fittings and hoses with T's...
I was never happy with it so I swapped in a manual rack. Turned easier that way. I hate having anything on the car rigged up.
