- Mon Apr 12, 2010 2:58 pm
#187208
Just pulled the head off the 1994 civic 1.5l. Ran into a problem im not to sure if i can fix. the head bolt right above the oil presure sensor is screwed... Looks like someone done some engine work on this car with fresh pistons and lower block work and when they put things back togeater they crossed this bolt... same spot where the head gasket was leaking... I was able to take another old bolt and run it in and out a few times but dont think thier will be enough threds for tourque... Is it possible to coil this and hold or is this block screwed?
but i will say i have used a head stud on blocks that have had partial pulled threads...
PANDA CREW No.20
PANDA CREW No.20
