- Mon Aug 30, 2010 11:07 pm
#211300
That One Dude wrote:Dude. I've never been a D-series guy, or had much respect for the D-series as a huge power maker, but that is simply awesome.Thanks man. I actually need to trim it a bit, and after that, it'll sit just inside the fender where it shouldn't have any clearance issues. I was actually going to use some aircraft rivets. I have some up at the hanger about 40 miles away. My other hobby is flying. After this is up and running i'm going to focus on finishing an Acrosport II aerobatic bi-plane that my grandfather and i started a few years back before he passed away.
I hope you don't take this wrong, but coming from an aircraft mechanic, you might want to put a little more space between the steel of the fender and the exhaust stack you have there. Mofo is going to get hot. Quick. And I think your exit location would look even better if you weld the doubler to the fender.
If you want, I can snag some pull type rivets we use on airplanes and mail them to you. They're structural grade, and will hold better than the pop rivets in your coinslot fasteners and heat shield.
D16z6. Golden Eagle. AFI Turbo. Precision Turbo. Hondata. CG racing.
618hp, 407tq SOHC 10.68@137
My 92 hatch SOHC build. Quest for +600hp. Check it!
hes gonna get you now that hes fetured in the honda tuning mag this month!!!! j/k good shit tho!!!
