- Mon Sep 13, 2010 3:03 am
#213321
so i got my si runnin and put my z6 with the super charger in it, well when you drive it runs perfect when you get on it, and if you drive it normal it runs good from idle to 3k then stumbles till 4k and runs good after that.
there are no cels, ohh and if im just cruisin down the sreets after like a min of a constant rpm it will start to sputter and i have to push the clutch and give it a rev and that seems to clean it out. anyone got any ideas???
did you at least fallow the instructions from Jackson Racing on how to pull the timing with your factory ecu?
