- Sat Oct 16, 2010 12:52 am
#218523
should be true i dont see why it wouldnt just try it and see i dont think it will hurt anything
- Sat Oct 16, 2010 1:26 am
#218532
The engine will start and run. however wont run correctly. as your not using the correct fuel and tming maps.
BTW OEM GSR is P72. P28's can be chipped to run p72 Software however a stock p28 will Run a GSR quite crappy.
- Sat Oct 16, 2010 7:40 pm
#218593
I would stick with the stock p72
- Sun Oct 17, 2010 9:59 pm
#218709
The P75 ecu will start and run the gsr motor. It will not feel or act anything like an LS though. The fuel and timing maps will be off, you might also get detonation from the sheer fact that the GSR has a higher CR than a LS.
1986 Nissan 300zx
1980 Kawasaki KZ650
2014 Kawasaki Ninja 300
1980 Kawasaki KZ650
