- Sat Feb 11, 2012 5:06 am
#294398
Pull out your spark plug wires from the valve cover, I bet you there's oil in your spark plug chambers messing with your spark.
- Sat Feb 11, 2012 5:12 am
#294399
He just replaced the dizzy
EJ1_MK wrote:IAC will not cause it not to start when warm it is the ICM in the dizzy. Friends car just had this happen to his z6 in a 94 del sol and he replaced his dizzy and boom fixed. So go with the ICM and the coil first.
- Sat Feb 11, 2012 3:50 pm
#294428
no oil they are nice and clean.
new dizzy came with all the stuff inside of it.
Wicked wrote:Pull out your spark plug wires from the valve cover, I bet you there's oil in your spark plug chambers messing with your spark.
Apexracing wrote:EJ1_MK wrote:IAC will not cause it not to start when warm it is the ICM in the dizzy. Friends car just had this happen to his z6 in a 94 del sol and he replaced his dizzy and boom fixed. So go with the ICM and the coil first.
- Sat Feb 11, 2012 6:57 pm
#294451
Did you check your wires themselves? In terms of bad wires not completing a circuit.
- Sat Feb 11, 2012 11:08 pm
#294490
went to york today... stopped by advance on the way there and picked up a new main relay... still didnt start when warm.
went to another advance and picked up a intake air temp sensor(the code that was thrown) and coolant temp sensor just to give it a try. replaced the AIT and it seems to have fixed the problem. starts idles runs fine. took it for a drive, still starts right back up i even stalled it on purpose and it still starts right back up... crossin my fingers hopin i finally solved the mystery
still have the pulsing rpm deal goin on but the starting issue is solved for the time being anyway
- Sat Feb 11, 2012 11:10 pm
#294491
for the pulsing rpm, spray around vacuum lines for air leaks, also the intake manifold. And clean out the fast idle valve.
- Sun Feb 12, 2012 2:09 am
#294504
heres what the old and new AIT looked like side by side. the old one was gunky and looked slightly melted
I checked for leaks back in the fall but didnt find any. ill check again next chance i get.
do you mean the fast idle thermo valve? I "adjusted" mine about a month ago by following the directions on this site.
http://www.superhonda.com/forum/f55/tro ... ms-259965/
it helped the idle alot along with cleaning the IACV for like the 4th time in 2 years.
how do you clean it?
Apexracing wrote:for the pulsing rpm, spray around vacuum lines for air leaks, also the intake manifold. And clean out the fast idle valve.
- Sun Feb 12, 2012 2:17 am
#294508
yup that valve remove it and clean it out with carb cleaner. when all else fails my 93 accord had pulsing idle i sprayed around the intake manifold gasket and low and behold it leaked. so i replaced it.
- Sun Feb 12, 2012 2:21 am
#294510
my idles fine its pulsing from like 1,800 to 2,500rpms and only while driving
- Mon Feb 13, 2012 4:29 am
#294685
drove about 30 miles today with about 5 stops. shut it off and restarted it right away without a problem. I think the problem is fixed finally.
- Thu Feb 16, 2012 4:39 am
#295150
well I took a can of carb cleaner and sprayed every gasket, seal vacuum line and everything else I could possibly find. no leaks at all
so I just take the plate off and spray this thing with some carb cleaner?
Apexracing wrote:yup that valve remove it and clean it out with carb cleaner. when all else fails my 93 accord had pulsing idle i sprayed around the intake manifold gasket and low and behold it leaked. so i replaced it.
- Thu Feb 16, 2012 4:49 am
#295153
Back that white screw out all the way and pull out the guts and realy clean and wipe them down. Then put it back together
