My 1992 SOHC Turbo Hatch
teal_dx wrote:how are you sure the clutch is not engaging at high rpm? by that do you mean it is not grabbing or that it is not disengaging, causing your tranny to grind when shifting?
teal_dx wrote:sounds like your synchros may be done. 3rd seems to be the one that wears out the most.
unless there is still some air in the clutch line. Did you do/modify anything before this started happening?
