- Thu Aug 14, 2008 11:38 pm
#66011
So my wire tuck is complete! *cheering from nowhere*
But before you all break out into song and dance...the journey is not yet over. My car still won't start. This is to be somewhat expected seeing as how, 1: this is my first time doing this, and 2: I did it slowly during my spare time over a span of about 2 months...so I probably missed some things.
Right now, I turn the key to the "turn on the engine point" And nothing happens.
If I leave it turned as much as it will go (the second setting) The stereo works just fine but these following problems occur...
- Tail lights come on for no reason. Whether or not my headlights are set to "on or "off"
- My "right hand turn signal" light is on. Not FLASHING mind you...just...on. Also, doesn't matter what my turn signal "lever" is set to. It's always on.
- There is a strange, yet subtle, humming noise coming from what I presume to be SOMETHING relative to the climate control.
- My "check engine" light is on. Which is ok because I have some things not plugged in in there.
- My "oil" light is low...odd because I have more than enough oil in the engine...but I believe it has something to do with a sensor.
- This next one is odd...my "battery" light is on. Very odd seeing as how my stereo and lights work yet it's claiming it's dead.
The main issue here however is that when I turn the key, it does absolutely nothing. Not even TRYING to turn over.
I will be out in the shop slaving over these issues, but if you guys have any ideas PLEASE let me know things that I could try to speed up my troubleshooting.
Thanks
Thanks
