- Tue Sep 02, 2008 7:15 am
#68013
Hi All,
I am in the process of getting a Welder to fix the panel on my 93 Si Coupe, It will mainly be use to weld thin body panel. The one that I am interested in is the LINCOLN ELECTRIC HANDY MIG WELDER with the gas
accessories all set up.
Has anyone use this welder? ratings,,.
Is 35 Amps low enough to weld on the Civic's panel?
The panel is thin, I think Its 24 gauge mild steel.
This welder is rated at 35-88 amps 4 settings.
The main reason I am picking this welder is the cost factor.
It is very cheap at Sears in the states ($299).
Thanks,
Thanks,
