- Fri Jan 23, 2009 8:24 am
#91793
Well i have finally had time to sit down and write this up..
This is just front for now
Lowering Your car with ebay Coil overs with sleeves...
Tools:
1 - 12 mm Wrench & Socket
1 - 10 mm Wrench & Socket
1 - 14 mm Wrench & Socket
1 - 17 mm Wrench & Socket
1 - 5mm alankey
1 - 3/8ths Drive Ratchet
1 - Jack
2 - Jack Stands
1 - Tire Wrench
1 - Bottle of Liquid Wrench *optional*
And most important
1 Case of Beer or Booze of Chose
Step 1:
Loosen Lug nuts, But do not take off yet. Repeat on the other side.
Step 2:
Pull ebrake and Block rear wheels:
Step 3:
Jack up and Put jacks under.
Step 4:
Remove lug nuts and wheel. Repeat on the other side.
Step 5:
Loosen Bolt in Red section and remove. Bolt and Nut are 17mm ( use liquid wrench if rusty and worried about snapage )
Step 6:
Loosen Bolt in Red section and remove Both are 12mm ( use liquid wrench if rusty and worried about snapage )
There is a 3rd bolt just inbehind those two that have to be removed as well, its a 14mm( use liquid wrench if rusty and worried about snapage )
Step 7:
Remove Fork From the bottom of the shock and just pull it forward
Step 8:
Now you have to remove the 2 - 14 mm Nuts holding the Shock in at the shock tower
Step 9:
Remove Shock and Strut as one and you will have a hole like this one
Step 10:
Now your Shock and strut will look like this
Step 11:
Now you take your 5mm alankey and 14 mm wrench and put it on the top nut and loosen till it all comes apart. No you do not need a spring compressor. but be careful point the alankey and wrench at a piece of foam or cardboard. and BLAM its aprart
***** im gonna finish the rest in a bit aka tomorrow*****
Tools:
1 - 5mm alankey
1 - Jack
2 - Jack Stands
1 - Tire Wrench
And most important
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
www.kelownacivics.com
www.vancouvercivics.com
Build Thread >> http://civic-eg.com/viewtopic.php?t=11803
jamminator wrote:my hatch looks wet all the time... kinda like the girls in it.
im broke and dont have many tools. nothing wrong with having an expert do it for free with the right tools.
