- Tue Aug 31, 2010 11:56 pm
#211531
eg84dr wrote:d15b rods are very unique
they have the same length as d16z6 rods but have diffrent rod journal
d15b rods are basically d15z1 rods that are longer
NO they aren't. None of you have been reading anything I have written. Or anything that has been written about the D15B ... have you.
The JDM D15B is the same block as the USDM d15b7/b2/b8 ... the difference is the crank shaft it has d16 sized rod journals. It's basically a shorter dd16 rod.
The d15z1 has a longer rod (137mm, same as a d16) but uses the same crank as the d15b7, the reason for this is the wrist pin height on the z1
pistons.
Rod/length/BE bore (size of the part that attaches to the crankshaft)
d15b7/134mm/45mm
d16(all)/137mm/48mm
d15z1/137mm/45mm
JDM d15b/134mm/48mm
Is that clear enough ... or do you need to be spoon fed even more.
Straight lines are for sissies.
